Thingworx - Azure Connector
We are trying to connect Azure IoT hup with thingworx. While executing "ConnectionServicesHub" thing's remote services, we are getting "ConnectionServicesHub does not support remote services". Can anyone help me with this?
Sathishkumar C.
raluca_edu
Please check the resolution from here: https://www.ptc.com/en/support/article/CS252401
Hope it helps,
Raluca Edu
Hi raluca_edu,
Thanks for your reply & support. I already tried the same but it wouldn't help me.
Sathishkumar C.
Support
Hi @Sathishkumar_C.
Which version of ThingWorx are you running?  You must be running ThingWorx 8.5+ in order to run Azure IoT Hub Connector 3.0. Here is a link to the support matrix indicating the versions supported (scroll down to find it).
Here is also a link to the Help Center that provides more information on the Azure IoT Hub Connector.
--Sharon
