ThingWorx C SDK Example issue
Hi all,
I am using following the C SDK guide:
https://developer.thingworx.com/en/resources/guides/thingworx-c-sdk-tutorial/sample-code-c-sdk-tutorial
At the guide, I am trying to follow the 'ExampleClient' example (step 3). I am building the example code properly, and I establish a connection to the platform. However, when I monitor the 'thing', I see it as an 'unbound', unlike the example. I have tried using the 'Administrator' user for the application key, but it didn't help.
What am I doing wrong?
Thank you for your time
Support
Hi @soft_dev.
I'll have to test this in order to provide any feedback so will need a little time to do that.  As soon as I have more information, I will let you know.
--Sharon
Are you able to show your Monitoring screen? If not, are you able to provide what 'Thing' you're trying to bind? Or are you running the code without changes?
