Thingworx calling Report Created By Query Builder
I'm sure this has been answered, but I cannot for the life of me find it.
I have a report in Windchill written in Query Builder that I would like to leverage inside of a Thingworx thing.
It takes two parameters
partNumber
partView
The id is 12345
How do I call this report?
Any help is appreciated!
First of all you will need to configure connection between Windchill and ThingWorx. You can find documentation in the PTC Windchill Extension Guide.
As part of this you need to deploy Windchill Rest Services (WRS) and Windchill patch for ThingWorx. The REST API is self documented in Windchill. To enable the icon you have to set the Client Customization preference to yes in the Windchill UI.
Unfortunately currently there is no REST services to execute Windchill Query Builder report directly and currently is not possible to extend this out-of-the-box Windchill REST WebService.
So you will have to build and test InfoEngine task to invoke such report and then in ThingWorx invoke your custom I*E task using the ExecuteTask service on the WindchillConnector thing. See "Using Info*Engine Tasks when Developing Your Application" in "PTC Windchill® Extension Guide".
Support
Hi @acoash1.
If the previous response allowed you to solve your issue, please mark it as the Accepted Solution for the benefit of others with the same question.
--Shaorn
