Apr 26, 2024 9:36 AM UTC
ThingWorx display different time than DB had
Hello all TWX masters.
I installed TWX  9.3.6-b1323 from installer  and I have strange behaviors with time.
I have some records in MSSQL DB with time 14:05:56 but when I execute it from TWX side I have 16:05:56...
I checked server time - its ok
I checked DB time - its ok
I execute TWX service like getDate() - its ok
I checked Tomcat JVM setting (-Duser.timezone=UTC) so its ok...
I have empty mind where it could be a problem...
Best regards,
Jan
Apr 26, 2024 10:26 AM UTC
All datetime objects displayed in Thingworx (Composer or Runtime) are converted to your browser's time. If you want to see the "raw" time, convert the datetime object to a string and let the service display it. Another way would be to log it in the ScriptLog.
Apr 26, 2024 10:30 AM UTC
You know it happen when I execute SQL Query from Connectors. It only happen there. I mean when I ask about DB data.
All Date on datepickers ect works as it should.
I have two env on one single browser with TWX 8.4 - works perfect. With 9.3 works with 2 hours delay.
