ThingWorx Edge SDK Java samples to create valueStream
Hi Guys,
I have been trying to create a ValueStream through Edge Java SDK, couldn't find any solution how to create that.
But i'm able to set the existing ValueStream to a particular thing using SetValueStream service.
Is it like ValueStream need to created while creating a thing itself or do we have any particular service to create a ValueStream explicitly.
Could someone please help it out.
Thanks in advance.
slangleyAnswer
Support
Hi @kiran2.
Since a ValueStream is just a Thing created using the ValueStream template, you should be able to create it using the CreateThing service under the EntityServices resource.
If you still have questions, please let us know.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @kiran2.
--Sharon
kiran21-VisitorAuthor
Thank you @slangley ,
The solution you provided got worked.
