Thingworx Extension Eclipse
Hello Together,
I'm facing the following issue when install Thingworx Extension with Eclipse.
Cannot complete the install because one or more required items could not be found.
 Software being installed: ThingWorx Extension Builder 7.2.0.201608021836 (com.thingworx.eclipse.extension.feature.feature.group 7.2.0.201608021836)
 Missing requirement: ThingWorx Extension Development Environment 7.2.0.201608021836 (com.thingworx.eclipse.extension.ui 7.2.0.201608021836) requires 'osgi.bundle; org.eclipse.wst.server.ui 1.5.100' but it could not be found
 Cannot satisfy dependency:
 From: ThingWorx Extension Builder 7.2.0.201608021836 (com.thingworx.eclipse.extension.feature.feature.group 7.2.0.201608021836)
 To: org.eclipse.equinox.p2.iu; com.thingworx.eclipse.extension.ui [7.2.0.201608021836,7.2.0.201608021836]
Eclipse IDE Version:
Eclipse IDE for Java Developers
Version: 2019-09 R (4.13.0)
Build id: 20190917-1200
rosharmaAnswer
hi,
i think it might be missing required eclipse version 4.5 or newer
follow the article for further clarifications
https://www.ptc.com/en/support/article?n=CS233537
rosharma16-PearlAnswer
hi,
bot1q1-VisitorAuthor
Thank i needed the Enterprice Java Eclipse
