Thingworx Flow installation
Hi all, I have some trouble when try to install Thingworx Flow. I have installed on my server TW 8.4.3 and I want to integrate Flow. But, when I try to do that, I always received same message and when I try to log in into Flow, I see 404 error.
Hello mmancin,
Which url are you using to access Flow?
Is the server installed in your local environment?
It's rather sensitive when it comes to the url being used.
It could be that you either provide the wrong port or the wrong ip to access it.
Pascal
mmancin1-VisitorAuthor
https://<ip>:8443/Thingworx/Composer/apps/flow
The server is installed locally
Hello mmancin,
It's possible that the URL expected is in this case the machine name, expecting this is a installation on Windows.
Do you also get a certificate error when trying to access from the browser? (usually visible as a red lock icon in the url bar)
Pascal
