Thingworx Flow Testing
TWX Trial 4.5.
TWX Analytics 4.5.
TWX Flow 4.5.
I am trying to test a simple Thingworx Flow - using GetProperties.
Is there anything particular that I need to do in order to test a Workflow?
If you look at the attached screenshot I start the Flow test but nothing happens. Can Flow simulate conditions or does the underlying logic have to be running (in this case an alert).
I used pm2 ls and everything is online. Is it the browser I am using? I ignored ssl errors as I am using Google Chrome.
raluca_edu
I don't know if you can test such a flow directly from Flow window, but to be sure try to trigger an alert on the thing from the screenshot and then check if the Flow was executed.
Also, have you tried to test a simple flow? Try to make a flow that has only a Logger and then test it by clicking TEST button. If it is executed correctly, then also your Thingworx Flow should work.
Hope it helps,
Raluca Edu
