Thingworx Foundation Installation Problem on Windows 7
- 7 replies
- 5767 views
- Translate All
Hi
My System Configurations are:
> Windows 7 Professional 64 bit SP1
> RAM : 4 GB
> Core 2 duo, 2.94 GHz
I Installed Thingworx Foundations 8.4 Trial (was working fine)
Uninstalled it after a month (due to errors/misconfiguration)
Installing it again is giving following errors(images attached):-
Error running .\check-http-response --username "Administrator" --password **** --hostname "localhost" --hostport "8082" --useSSL=0: 1
[17:41:28] Post-Install validation step failed check-http-response script returned ::1 writing file to mark install as failed.
Problem running post-install step. Installation may not complete correctly
[18:03:03] - The installation failed. Cleaning up
Error occured while running postInstall Validation scripts
Kindly reply back and help with the solution
