Thingworx foundation Trial H2 installation fails
I am using windows 10 Pro as a platform.Whenever trying to install Thingworx Foundation Trial Server its ended up with this message:
There has been an error Thingworx foundation Trial H2 installation failed.please check the logs.The application will exit now.
(It appears just near to the completion of the installation process)
I've tried many solution mentioned here like, clearing registry and Temp folder after each unsuccessful installation attempt.Setting up environmental variables.Pointed JDK file in JAVA HOME.Having JDK 1.8 installed in my system.I am attaching here log file.Please advise me
Hi @Kalpesh744
Can you find the file
C:/PROGRA~1/THINGW~1.0\installer\logs\foundation-20200513121114.log
Do you have some bitrock* files under %TEMP% ? if yes, please upload them here.
 Could you post the output of command set executed in a command prompt ?
Christophe
