Jul 8, 2024 7:43 AM UTC
ThingWorx grid with Column Span
I want to bind the Database record in a ThingWorx grid with "Column span" as shown below. I am using the ThingWorx version 9.3.8-b1504. Kindly suggest me with the steps and which Grid should I use for this cause?
Jul 8, 2024 7:48 AM UTC
Hi @SKannapiran
Look at the below article, and let us know if it will work in your use case.
https://www.ptc.com/en/support/article/CS246332
Jul 8, 2024 9:29 AM UTC
Hi @Surya_Tiwari ,
In my above screen shot, i am expecting a comparison functionality to be implemented in the ThingWorx Grid (i.e.., Column Span). Your reference link is to Change the "Grid" columns dynamically in ThingWorx.
Jul 15, 2024 9:22 PM UTC
Hi @SKannapiran  As per your requirement you need to create a custom widget.
