ThingWorx HA- Azure Postgresql
We are working on ThingWorx HA using ThingWorx 8.4.4 version.
We are planning use Azure Postgre sql database.
In Azure Postgre sql, there are 2 options 1. Single Server 2. Hyperscale Server group
which one is best option?
What I understood is stores more than 100GB data using Hyperscale Server group
If we use single server , can't store more than 100GB data?.
Could you please suggest which one is best?
Thank You.
Latha
Hello, Latha.
We'd need to know more about your use case(s) to give a good recommendation. How much data (approximately) are you planning to store?
Also, if you are not familiar with the ThingWorx Sizing Guide, please give that a look to see what you might need given your overall capacity requirements.
Thanks!
-- Craig A.
