Thingworx installation
I have to install Thingworx 8.5 on RHEL 7.6 with Postgresql and influxdb. I need to know where the data is stored and what size to calculate to create the file system and the corresponding partitions. My client asks me for that information. I will install as a user with few privileges. Thanks
PaiChungAnswer
22-Sapphire I
There is an export Data function as well in Import/Export have you tried using that?
22-Sapphire I
This might get you started
https://www.ptc.com/en/support/article?n=CS186102&language=en&posno=1&q=thingworx%20sizing%20guide&source=search
Just remember that Influx is only used as a persistence provider to store Stream and ValueStream data.
anaclos14-AlexandriteAuthor
Thaks, PaiChung. I was reading the documents. I created a very simple Thing and saved the data to influxDB as persistent provider using a Value Stream. Now I need to export data from one instance of Thingworx to another. I exported the entity but I don't know how to export the influx data.
PaiChung22-Sapphire IAnswer
22-Sapphire I
