Thingworx License restrictions
Hi Folks,
I have Thingworx 9.2 running and wanted to confirm if as per the License are there any restrictions on number of Mashups creation similar to no of users restrictions?
TIA.
slangleyAnswer
Support
Hi @TanmeyTWX.
There is no limit on the number of mashups that can be created assuming your licensing allows mashups to be created.  You can refer to Monitoring > Subsystems > Licensing Subsystem Settings in Composer to view counts.
--Sharon
TanmeyTWX17-PeridotAuthor
Hi @VladimirN,
Thanks for the reply.
I'm aware of the user access(feature count) limitations as per license type. But I just want to confirm if there is a restriction on count of Mashups creation as well for a specific license and that I couldn't find in Support page.
I believe there's no such limit on number of Mashups creation for a paid license.
Rocko
There is no such limit, but questions like this you might want to clarify "officially" with PTC support.
slangleyCommunity ManagerAnswer
Support
Hi @TanmeyTWX.
--Sharon
Hi @VladimirN @slangley @Rocko
Please let me know if the same license key can be used in two Thingworx instance?
Scenario: I did configure the license key in Thingworx test server A and now I have another test server B. So Can I use the same key from A into B?
@TanmeyTWX
There is no such thing as "licence key" in the ThingWorx world, if by key you refer to a sort of code or string.
There is a license file instead, which is specific to your local ThingWorx installation, and, as a result, can not be used or shared across more than a single ThingWorx server.
I suggest reading this Help Center link that contains what options you have for licensing in ThingWorx.
