Dec 19, 2025 6:09 PM UTC
ThingWorx mashup display on TV using a digital signage tool AppSpace
Does any one here know how to display ThingWorx mashup on TV using a digital signage tool AppSpace?
Dec 21, 2025 6:42 PM UTC
Some useful materials:
18-Opal
Dec 21, 2025 8:26 PM UTC
ThingWorx mashups are just normal HTML pages, so just open the one you need and copy the URL into your digital signage configuration. You’d need to handle authentication though:
1. Create an App Key for a user that has sufficient permissions to view that mashup. You can start with Administrator for a proof-of-concept.
2. Enable “Allow Application key as URL” in the Platform Subsystem configuration.
3. Add &appKey=xxxxxxx to your mashup URL. This should log you in without asking for credentials.
Of course this assumes that your digital signage installation is connected to Internet. Otherwise you’re out of luck.
/ Constantine
Dec 23, 2025 6:02 PM UTC
Thank you for the reply
If my site is SSO authenticated (Azure AD) - will the
2. Enable “Allow Application key as URL” in the Platform Subsystem configuration. - Skip the authentication?
18-Opal
Dec 24, 2025 1:05 PM UTC
Theoretically it should, as long as you have App Key authentication enabled in your sso-settings.json.
