Thingworx mashup for Azure Datalake
I am using Thingworx database to store one week data from manufacturing plants and use Azure Datalake to store older data. Is there a way to use Mashup to view historical data from Azure Datalake? I know I can use PowerBI to view historical data. But I want to use the same tool to see both real time and historical data.
slangleyAnswer
Support
Hi @zackp.
We don't have a connector out-of-the box for Data Lake, but you should be able to build one.  Another option would be to move the data to blob storage in Azure, then configure the Azure IoT Hub connector that we provide for accessing the data.  A third option would be to export the data in a format that could then be accessed by ThingWorx via your mashup.
If you have more details you can share, we might be able to provide a more comprehensive suggestion.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @zackp.
--Sharon
