Jun 16, 2020 3:29 PM UTC
Thingworx mashup widget horizontal slider: input array of values
I need to input an array of values in the horizontal slider widget, instead of defining min/max/step.
How can I achieve that ?
Thx.
PaiChungAnswer
22-Sapphire I
Jun 17, 2020 1:38 PM UTC
Ahh sorry, that isn't possible
22-Sapphire I
Jun 17, 2020 1:05 PM UTC
A slider will not accept an 'array' or infotable directly.
If you are outputting an infotable and it is a single row, you can expand Data and take the individual values and bind those to min/max/value
If you are using a multirow infotable, you would use selected row(s) in a similar way
Selecting from Data (All Data) it always provides the 1st row.
Else you'd have to return three individual values, unless these values are properties, then you can also use getproperties
SBO1-VisitorAuthor
Jun 17, 2020 1:11 PM UTC
it's not about the infotable data input manipulation, I am referring to making the slider allow selectable values only those that I choose.
Example:
currently the slider widget sets min/max/step (1/10/1) and the selectable values will be 1,2,3,4,5,6,7,8,9,10
I need to have the slider offer the user only the values 1,4,6,7,10
PaiChung22-Sapphire IAnswer
22-Sapphire I
