May 24, 2018 2:38 PM UTC
ThingWorx Nagivate - Data Export for app PartsList via extension DataExporter
Dear all,
we are currently working with Navigate and we try to implement a better data export feature than the default solution. By default TWX Navigate exports only to CSV format and we want a MS Excel sheet.
Therefore we use the Extension "DataExporter", my question is now, how can I test the changes?
I linked the "ExportInfotableAsExcel-Service" from the installed Extension to the "Export All"-button from the Navigate App, but I can't load the app properly with data to test. Everytime I start the app it uses the default mashups from Navigate and the default export mechanism.
Has anybody any tipps or tested something similar with the mentioned extension before?
I know already that the extension is buggy, but I want to see it anyway (https://community.ptc.com/t5/ThingWorx-Developers/Export-InfoTable-As-Excel/m-p/519873#M15287).
We use TWX 8.1 and Nav 1.6 together with WC 11 M030. The in between TWX and WC 11 is working fine.
Thank you for your support
Benedikt
