Jul 7, 2026 9:50 AM UTC
Thingworx not up and running after deploying war file
I am using ThingWorx Platform Release 9.2 and DatecodeSP12 C3P0PooledConnectionPoolManager[identityToken->2y7va1bjf5tzhngvxv49|58599b34]-HelperThread-#2] Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@f2f0838 is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests. Here are the errors that I faced C3P0PooledConnectionPoolManager[identityToken->2y7va1bjf5tzhngvxv49|58599b34]-HelperThread-#2] Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@f2f0838 is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
raluca_edu
Jul 8, 2026 1:42 PM UTC
Probably, Thingworx cannot connect to database from various reasons.
Please check this article: https://www.ptc.com/en/support/article/CS313498
Hope it helps,
Raluca
raluca_edu
Hope it helps,
Raluca
Support
Jul 14, 2026 8:34 PM UTC
Hello ​@JJ_10299656,
I hope you are doing well.
I am following up on your post to check whether you are still experiencing the issue. I also wanted to see if you had an opportunity to review the KB article shared by ​@raluca_edu.
If the article helped resolve your issue, please consider marking the response as the Best Answer so it can help other community members facing a similar problem. If you are still encountering issues, please share any error messages or additional details.
Abhi
