Thingworx opening in limited mode after upgrade
Hello, I recently upgraded an old Thingworx server from 7.4 to 8.1, and it is opening in limited mode when I believe I have a valid license. The App log says:
"No new License capabilities from license server".
and
" Unable to fetch license file with device id xxxxxxxx"
I did a disconnected license retrieval and have double checked my permissions/naming yet the license_capability_response.bin is getting ignored. Is there a way for you to check if my company is out of licenses? I'm a little unclear on how the licensing subsystem works. Any help you can provide would be great.
Thank you
Connor
slangleyAnswer
Support
Hi @clansdale.
For the sake of others on the community, this issue was the result of a new Device ID being generated during your upgrade.  The solution was to obtain the correct Device ID by running the GetInstanceID service, then generating and installing a new license.
If you are in agreement that this was the solution, please mark this reply as the Accepted Solution.
--Sharon
I am assuming that a restart was done or the AcquireLicense service from Subsystems -> LicensingSubsystem was executed after the new license was placed in ThingworxPlatform folder
I hope you have relocated any old license.bin file from ThingworxPlatform folder
By this, do you mean license_capability_response.bin file is being renamed to ignored_license_capability_response.bin?
clansdale1-VisitorAuthor
Yes, I moved the old license.bin out of the ThingworxPlatform folder.
And also yes the license_capability_response.bin file is being renamed to ignored_license_capability_response.bin after startup.
Would a restart corrupt the license? How should I proceed?
Is it possible that during upgrade you may have accidentally deleted the below files?
  1. ThingworxPlatform / keystore-password
  2. ThingworxStorage / keystore.jks
If so, please refer this article.
If this does not help either, please open a support ticket.
