Thingworx proper login system
Hi!! i have the authetication extension and i can use a external page to authenticate a user. But this still as it's flaws, for example: if the password or username are incorrects the page will be redirected to a formlogin.
I want to go further, i want to create a actual login system inside thingworx, is it possible ? what do i have to do ?
Thank you.
22-Sapphire I
OOTB Thingworx provides the FormLogin (Organization approach)
Outside of that you can use the SSO approach that works with your IDM system
@PaiChung , thank you for the response, can you please elaborate ?
Support
Hi @xotzHelper.
Here are a couple of links that might be helpful:
Login Authenticators
Create an Authentication Extension
If you still have questions after reviewing this information, please let us know.
--Sharon
Support
Hi @xotzHelper.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
