Thingworx Service C# Call
  • July 31, 2016
  • 3239 views
Hi Everyone,
I am trying  to integrate thingworx into a .Net Web Application. I need to call a Tw Service but it does not work.The service returns an InfoTable
I enabled Allow Request Method Switch in Tw
Bellow is the code
var req = (HttpWebRequest)WebRequest.Create(url);
            req.Accept = "application/json";
            req.Method = "POST";
            req.ContentType = "application/json";
            req.Headers["Authorization"] = "Basic " + Convert.ToBase64String(Encoding.Default.GetBytes("user:pass"));
            HttpWebResponse resp = req.GetResponse() as HttpWebResponse;
For the GET verb it works but it returns the service signature which is useless, but for POST it returns "The remote server returned an error: (400) Bad Request"
Dou you have any Samples of REST calls using C# ?
Thank you,
Tudor
Best answer by tbugnar
It is working.
It was a mistake in the service URL.
original
https://ptc-url/Thingworx/Things/MyThing/ServiceDefinitions/MyService
correct url
https://ptc-url/Thingworx/Things/MyThing/Services/MyService
tbugnar1-VisitorAuthorAnswer
