ThingWorx to MQTT
Hello. I am trying to implement a digital Andon solution. In order to trigger an issue, I must publish to an MQTT topic on a specific endpoint (so from TWX -> external MQTT endpoint).
Is that possible to do from a Javascript TWX service? Or do I have to create my own proxy behind a regular HTTP API to accomodate for ThingWorks lack of capability in this regard?
Googling is difficult because it seems apparent that TWX is capable of becoming a MQTT-server, but I need it to act as a client. Possible? How?
rjanardanAnswer
You may use the MQTT Extension to publish/subscribe to MQTT topics.
Quick start guide
Detailed Article
rjanardan16-PearlAnswer
Quick start guide
Detailed Article
Support
Hi @binaryPUNCH2.
If the response provided by @rjanardan answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
