ThingWorx TrialEdition Installation Docker Failure
i have a problem installing Thingworx Trial edition.
First i downloaded and installed  Docker.  After that i started the TW Installer. After a few seconds the  following failure appears.
Please  help me!
Hi
Here are a few steps to check:
- Did you ensure that docker daemon is running ?
- are you able to runt he docker sample by executing the following command: docker run hello-world ?
Some further info needed if the above does not help:
- what OS version are you using
- can you upload the log files created under the installation directory (C:\Program Files(x86)/ThingworxTrialEdition by default)
Regards
Christophe
