May 14, 2025 8:55 AM UTC
Thingworx User password is not working as expected : Unable to Login
I am using ThingWorx Platform Release 9.7 and DatecodeF000
We have 2 server both server facing same issue : User is unable to authenticate with legitimate password
Here are the errors that I faced
025-05-14 08:24:35.678+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Connection refused: getsockopt
2025-05-14 08:24:35.682+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Subsystem WorkflowSubsystem failed to start: Could not connect to RabbitMQ: Connection timed out.
2025-05-14 08:25:37.758+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ] [S: ] [P: ] [T: https-openssl-nio-443-exec-16] Authentication failed: Please make sure the credentials are correct.
2025-05-14 08:25:51.286+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ] [S: ] [P: ] [T: https-openssl-nio-443-exec-18] Authentication failed: Please make sure the credentials are correct.
2025-05-14 08:28:14.174+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ] [S: ] [P: ] [T: https-openssl-nio-443-exec-19] Authentication failed: Please make sure the credentials are correct.
2025-05-14 08:31:06.188+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ] [S: ] [P: ] [T: https-openssl-nio-443-exec-8] Authentication failed: Please make sure the credentials are correct.
2025-05-14 08:49:19.351+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ???] [S: ] [P: ] [T: https-openssl-nio-443-exec-10] Authentication failed: Please make sure the credentials are correct.
    May 14, 2025 11:21 AM UTC
    Hello @Deepak_kankhare
    Are you facing the issue for any particular user or it is there for all the users?
    You can also refer following article which might help
    https://www.ptc.com/en/support/article/CS311527?source=search
    please feel free to revert if you still face any further issues
    May 14, 2025 11:03 AM UTC
    Hi @Deepak_kankhare,  Have you used SSO?
    May 19, 2025 9:46 AM UTC
    No @Surya_Tiwari , we are using Basic Auth
    Support
    Jun 5, 2025 2:23 AM UTC
    It appears that there are several possible solutions to your question.
    Have you tried the methods below? Maybe you can also update the result if they are not working:
    If the above solves the issue, for the benefit of other Community Members who may have the same question, it would be great if you could designate one of the replies as the Accepted Solution.
    In the event that this response did not answer your question, please post your current status so that we can continue to support.
    Thanks for using the PTC Community!
    Charles
    Rocko
    May 14, 2025 12:35 PM UTC
    To test, create a new, local user and try to login with that.
    If that doesn't work, something might be wrong with your keystore.
