Nov 23, 2022 8:42 PM UTC
Time horizon forecasting In Thingworx Analytics
Hi community, hoping you are well, I am writing to ask you about the capabilities of Thingworx Analytics.
In the field of predictive maintenance, one of the key objectives is the detection of failure conditions before they present themselves. Concerning that, we'd like to know how that can be implemented in Thingworx Analytics.
For example, say you want to predict a pump failure. Failure conditions are known (e.g. zero pressure), and past data is labeled with a boolean "ok/fail" for each timestep. The main objective is not to know the status of the pump given the current conditions, but to predict whether the pump will fail in the short term, given the current trends in the data.
We've previously developed a model which can give an estimate of the current condition of a machine. The model was trained using historical time-series data. However, we're unsure of the way forward for developing a predictive model, which can give an estimate of the probability of a failure condition in the future.
Can you give us a hand with this? We only need some guidance about the next steps. We'll be very grateful if you have some documentation or a step-by-step that you can share with us. We could even schedule a meeting if you have the availability.
Thanks in advance for your help with this matter.
Kind Regards,
nsampatAnswer
Dec 1, 2022 4:20 PM UTC
Hello @JZ_10390102 ,
This appears to be identical to a case entered with Technical Support and our Engineer has provided you with information for your use case.
I will share his response here for everyone on the PTC Community to see if they have similar questions.
Please refer to the following links:
ThingWorx Analytics Server, gather timeseries data to predict Time to Failure
https://community.ptc.com/t5/IoT-Tips/Predicting-Time-To-Failure-with-ThingWorx-Analytics/ta-p/818152#M1095
Based on your feedback to the support engineer in your case, you have stated this provided a starting point/steps to begin your use case work.
With that indicated, would you be able to mark this thread as "solution accepted" if you have no further questions not answered in your case?
Neel
nsampat17-PeridotAnswer
Neel
