Time Series Chart from Extention will not work with different sources
Hey guys,
today I'm working with the TimeSeriesChart of the Custom Chart Widgets Extension (Version 3.0.0). I have multiple datasource which should be shown in the same chart. So I bind my services with the DataSource1, DataSource2 and so on. I uncheck "SingleDataSource" and setup the DataField and XAxisField properties.
The result of all this is an empty chart. Its dont show any graphs and no time axis.
If I do this stuff with the standard time series chart everything works fine. =/
The problem of the standard time series chart is as no ability to fill the area under the graph.
Have I forgot something todo on the time series chart from the extention?
Even i tried with a custom time series chart and able to get the chart. Can you check the service from which you are fetching the data on chart ? Can you test it manually and see if it is returning data there ? Mapping of data sources is pretty much same as it is in standard time series chart .
drichter1-VisitorAuthor
Do you bind the data with the "Data"-property or with the "DataSource1", "DataSource2", ...?
The Service I use is the standard QueryNumberPropertyHistory of a thing with some data. If I call the service manualy I get some rows with data.
 Can you try binding sequence wise ,like first the data then datasource-1 and then datasource-2 based on your number of series ?
