Time Series Problem
I'm encountering some basic problems with Time Series Chart - i dont see any values.
What i've done so far (including looking thru tons of post about it):
1. I have DHT sensor connected to arduino, which is posting requests to Thingworx, everything is working fine - values are updating. I've done everythin whats in  the https://developer.thingworx.com/en/resources/guides/display-data-charts/ddc-create-thing guide, created stream and dataShape.
2. i've created a mashup and I've put there Time series Chart, ive connected the querypropertieshistory service to chart etc. But nothing showsup.
    Have you :
    1. put the input infotable in a Grid widget to check if the value exist
    2. Have you select Y value field/ Source field?
    Hi @Szymon
    I just wanted to follow up with you to see if previous response was helpful for your question?
    If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
    If you are still experiencing an issue, are you seeing any errors in the logs?
    Vibhuti
