6-Contributor
timeline widget
Hello
I have to plot a process steps in a timeline, each step can have sub-steps that i would like to plot also.
i think about using the timeline widget, but i could not find how it works or an example f the inputs as an infotable nor json,
so my question is how to use this timeline?  Can i plot the process steps and as subgroups of the step's sub-steps?
Thank you
PEHOWEAnswer
@AR_10436872 , @Rocko ,
You can look at the installed Widgets. In Composer, click on the Manage,  Then click on "Installed Extensions".
This will provide a list of the Installed Extension Packages.  When a row is selected a list of the items in the package is displayed. If the package has a widget it will be displayed.  Because this display has a vendor and version information it can assist in identifying an extension.
Rocko
Please add your version of Thingworx and which widget you are referring to. There is no widget called "timeline" in the default installation.
6-Contributor
i am on ThingWorx 9.2.15.
i am taking a previous person's project , so i did nott know if it was imported as i don't find it in the installed extensions, and i do not know where i ca verify that.
it looks like this on the composer :
and like this on runTime
Rocko
Sorry, no idea where that is coming from. Maybe you can try to find a mashup on your system where it is used for an example,
