Timer on Mashup - Timer should run based on click event (Button)
  • April 1, 2017
  • 5 replies
  • 2621 views
Is there is any way to run timer on Mashup ? Timer should run based on button click event. Thanks in advance.
You can achieve that by creating a Service like below in a Thing and then bind this service to "Clicked" of a button Widget in your Mashup.
function sleep(time) {
  var d1 = new Date().getTime();
  var d2 = new Date().getTime();
  while (d2 < d1 + time) {
   return;
//Set how long you want to set sleep in ms
sleep(1000);
Hi Velkumar R​,
I suppose that you can use Autorefresh here. It can be switch on off on click event.
Please share your usecase in more detail to help me suggest more in this regard.
vr-61-VisitorAuthor
Hi Ankit,
When user click start button, timer should run on mashup and when user click stop button on mashup timer should stop. (Like StopWatch)
You just need to call Timer Thing EnableTimer and DisableTimer services.
