Timers and schedulers
 I have to run a task for every one minute from 8:00 a.m to 4:00 p.m Monday to saturday. How to do this?
SruthiAnswer
yeah, what about this?    0 0/1 8-16 ? * MON-SAT
will this work from monday to saturday?
raluca_edu
Managed to do a scheduler to run from 8 to 16 every day every minute with this expression: 0 0/1 8-16 * * ? *
I couldn't make it work on specific days of the week, but you can start with the above expression.
Hope it helps,
Raluca Edu
Sruthi15-MoonstoneAuthorAnswer
raluca_edu
At the first sight, yes, it is working.
I recommend to test it and follow it for 1 week to see exactly when it is running.
Probably, you need to change 16 with 15 (for the hours).
Best regards,
Raluca Edu
Support
Hi @Sruthi.
If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.  if you have found a different solution, please post it and mark that as the Accepted solution.
--Sharon
