pshashipreetham
Aug 8, 2026 9:25 AM UTC
Times InvokeCodeVentHandler Issue
Recently, I have been facing an issue with the timer, which is very critical for us.
Error Executing Event Handler 'InvokeCodeVentHandler' for event Type.Thing:Test.Timer:Event.Timer
I have gone through below Articles, but nothing helped:
Article - CS403375 - In ThingWorx Platform Error message: Error Executing Event Handler 'xxx' for event Type.Thing:Entity.xxx:Event.xxx is seen often in the Application Log
Article - CS333561 - Error Executing Event Handler '<Event' for event Type.Thing:Entity:<Thing>:Event.ScheduledEvent is frequently logged in the ErrorLog of ThingWorx Platform
Has anyone had this issue? And has any Root cause been found?
Aug 10, 2026 4:09 PM UTC
I would think it’s one of these issues:
  • user (which is set in timer) does not have permission for event subscribe or execute → try with Admin user. if issue disappears its permission issue
  • code inside of subscriptions creates error → try just add a logger and remove other code. if issue disappears and log statement can be seen its code issue
pshashipreetham
Aug 20, 2026 4:14 PM UTC
Thanks ​@nmutter, for the pointers.
As of now, we are working with the PTC-Support team.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Sep 10, 2026 4:50 PM UTC
ok, looking forward to the solution
Support
Sep 10, 2026 3:13 PM UTC
Greetings ​@pshashipreetham ,
Thank you for reporting the issue.
The error message indicates that the Timer event is being triggered successfully, but the associated event handler or service is failing during execution. The message itself does not identify the root cause.
To investigate further, could you please submit a support ticket.
Mohit
