Timeseries mashup
Hello sir,
Actually i am getting incoming json scripts in properties and alerts tab, In that json it contains timestamp,machinedatas, transcounter values, etc,. I need to show the transcounter value in mashup area. How to do that, can u please help me to do that?
    cmorfinAnswer
    @DMu3
    Could you please post a new topic with your question as this has nothing to do with the original question.
    This is important so that we keep post clear and to one issue so others can find easily the answer.
    In addition to your screenshot it probably will help to upload an export of the mashup and entities so one can see how the chart is being built.
    Thank you
    Kind regards
    Christophe
    22-Sapphire I
    Usually server side you'd use a script to parse out the information so it can be displayed in a Widget
    Potentially the Expression function can parse it out for display
    Or you could create a custom widget to do it.
    Route 1 or 2 would be the easiest.
    DMu31-VisitorAuthor
    Hii,
    Server side is not possible. Can we create some service ? If its possible means how to create service in thing to see particular value of json?
    You could parse JSON to populate an Infotable
