Timeseries model does not stop training
Hi!
I have submitted a timeseries model to Thingworx Analytics, and it has been running for a day without stopping. I have only about 4700 entries and look back size is 30, so it seems that should not take so long.
I would be very grateful if someone could advise any possible solutions or potential causes of such behaviour.
cmorfinAnswer
Hi Andrey
30 is actually a large number for the lookback size. Given the way ThingWorx Analytics processes this internally that will lead to a lot of processing indeed.
You should look at lowering this. Normally you should be able to set this parameter to 0, and ThingWorx Analytics will automatically sample between a lookback size of 2 4 8 or 16 to find the most appropriate ... as you see this still remain much lower than your 30.
Kind regards
Christophe
cmorfin19-TanzaniteAnswer
Hi Andrey
Kind regards
Christophe
azhylka1-VisitorAuthor
Dear Christophe,
Thank you very much that helped.
Best regards,
Andrey
