timestamp in thingworx do not match on windows 10 and windows 7
On Mashup, i am showing a timestamp. On hovering the timstamp in windows 10 it shows Coordinated Universal Time where as on Windows 7 it shows Greenwich Mean Time. ( Chrome Browser TimeZone is Coordinated Universal Time).
Normally the display settings to render the time will be to the browsers settings so you should check Browser config.  If you're still having an issue then you should open a tech support ticket.
