Jul 4, 2020 8:31 AM UTC
To remove deprecated widgets
Hi All,
Which approach I must follow to remove deprecated widgets ?
Approach 1 :
Already have mashups imported from previous version which are having deprecated widgets. Replace each deprecated widget with new one.
Approach 2 :
Redesign new Mashup completely with new widgets but then it will consume a lot of time for me.
If I go with approach#1 and remove all deprecated widgets will it still impact my mashup performance. Does importing mashup of previous version impacts performance even if we have replaced it with new widgets ?
I need this because at some points events are not working for mashups but working fine with new one.
PaiChungAnswer
22-Sapphire I
Jul 6, 2020 5:45 PM UTC
There are some automatic conversion capabilities, after that you should just replace old with new.
There shouldn't be a negative performance impact by doing that.
PaiChung22-Sapphire IAnswer
22-Sapphire I
Support
Jul 20, 2020 3:58 PM UTC
Hi @sid_jhs.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community.
--Sharon
