Tomcat 9.0.31 on ThingWorx 9.1.0
My customer is going to use ThingWorx 9.1.0 as the production system and Tomcat 9.0.37 is the official supported version .
However ,  the customer want to use Tomcat 9.0.31 as it's their standard pre-installed version in template VM machines,  and they have hundreds  of VM machines,  upgrading to 9.0.37 will bring lots of work.
So,  the customer want to know,  is there any problem if running ThingWorx 9.1.0 on Tomcat 9.0.31 ?
Sean
anarwalAnswer
Hi @seanccc , It may worked with tomcat 9.0.31 but I advise you to go with 9.0.37 because that is the minimum tested version for thingworx 9.1.0 and it also help to follow support level
anarwal5-Regular MemberAnswer
Support
Hi @seanccc.
If you feel our question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
