Sep 7, 2025 5:49 PM UTC
Tomcat 9.0 service stops after starting
I am using ThingWorx Platform Release 8.1 and DatecodeSP1
After a problem with the server where the RAM memory was saturated, the server had to be restarted, after this event the Tomcat service starts and stops shortly after.
Here are the errors that I faced
Faulting module name FlxCore64.Dll version 2016.8.0.0 exeption code 0xc0000417
    Sep 7, 2025 7:22 PM UTC
    Similar issue - "Thwx 7.4: Failed to load FlxCore library": https://community.ptc.com/t5/ThingWorx-Developers/Thwx-7-4-Failed-to-load-FlxCore-library/td-p/520920
    Rocko
    Sep 8, 2025 6:17 AM UTC
    8.1? Wow, that's real vintage, when was that released, like 2018? Not sure why you'd want to run a software that old, but if you did nothing else but restarting the server (e.g. updating some component), I would assume some files got corrupted. Do you have a backup?
    You can run a system check for the integrity of the OS files (I guess this is on Windows), also make sure there is no antivirus blocking the application, the error code suggests is could be that.
    Emeritus
    Sep 12, 2025 4:45 AM UTC
    Hello @AU_11025381,
    It looks like you have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
    18-Opal
    Sep 15, 2025 9:46 AM UTC
    Few things to try:
    1. Disable Memory Integrity in Windows
    2. Disable the firewall
    3. Check if you have multiple versions of this DLL in your system PATH
    4. Check the Event Viewer for more detailed or related error messages
    / Constantine
    Support
    Sep 17, 2025 2:58 PM UTC
    Hi @AU_11025381
    I saw that you opened a case for this issue.  Once the issue is resolved, I will provide an update here for the benefit of our community members.
    --Sharon
    Support
    Sep 29, 2025 1:44 PM UTC
    Hi @AU_11025381
    The case has been closed without a solution due to the lack of artifacts needed to investigate the issue.  Were you able to resolve the issue yourself?
    Your update on the solution you found would be greatly appreciated.
    --Sharon
