Tomcat severe error org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service()
I have observed below errors on Tomcat logs. Is there any problem?. We have observed server was not responding(500 Unexpected error). I am not sure because of below errors. Now also observing below errors but server is responding correctly. I am using Tomcat 8.5, Azure Postgre SQL version 10,Thingworx version 8.5.1 with HA configuration.
1. SEVERE [https-jsse-nio-443-exec-10] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause java.lang.NullPointerException
2. SEVERE [https-jsse-nio-443-exec-9] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause
at com.thingworx.webservices.context.HttpExecutionContext.commitResponse(HttpExecutionContext.java:515)
at org.apache.jsp.login.FormLogin_jsp._jspService(FormLogin_jsp.java:632)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:476)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:386)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:330)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:138)
at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:389)
at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:208)
at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:645)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:678)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:609)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:810)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1506)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
17-Jan-2021 00:42:11.959 SEVERE [https-jsse-nio-443-exec-6] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause
17-Jan-2021 00:45:37.464 SEVERE [https-jsse-nio-443-exec-3] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause
Latha
Hi @vi1
Thank you for reaching out to us.
Could you please provide the Tomcat and ThingWorx logs to investigate this further.
Based on the error which you have mentioned in post. Please check this CS227043 and see if it helps
Thanks & Regards,
Toolika Dixit
vi116-PearlAuthor
Thank you for responding. I will share you the Logs.
Latha
