Too much rows in autocomplete widget
In the MFG AssetMonitor Mashup, I use the autocomplete widget to search the AssetMonitorPerporty. But a lot of Assets has the similar name as the image. Can i limit the list in 10 rows ? I should customization the widget?
PaiChungAnswer
22-Sapphire I
The Widget receives it information through a service. You could replace that service with one that limits the number of records. Or you can completely replace the widget with a Filtering field into a Dropdown.
I would log that as a bug in support.ptc.com or request for improvement so that in a future iteration that can be accounted for.
PaiChung22-Sapphire IAnswer
22-Sapphire I
LiuDong5-Regular MemberAuthor
I customized the autocomplete widget and the scroll bar is work now.
