Jul 27, 2016 2:21 PM UTC
Transfer file from TW Server to remote JavaSDK
Hi Experts, Coluld you pls guide me on steps for
Transfer a file(zip) from TW Server to remote JavaSDK
I tried something, but not succeeded, using Copy service.
With that I cud achieve only copy a file between two folders, both on the TW Server.
My need is to copy a file from TW Server to remote JavaSDK.
Jul 27, 2016 4:37 PM UTC
Sujith,
You are correct in using the Copy service, but there are a couple of things you need to make sure are configured correctly:
  • A FileRepository Thing has been created on the ThingWorx server - in the following code sample (from a custom service) I've named my FileRepository "TestingRepo"
    • sourceRepo is the name of my FileRepository in ThingWorx
    • targetRepo is the name of the Edge Thing defined in the Java SDK
var params = {
  async: false /* BOOLEAN */,
  sourceRepo: "TestingRepo" /* STRING */,
  targetRepo: "FileTransferExample" /* STRING */,
  targetFile: "werd_2014.gif" /* STRING */,
  targetPath: "in" /* STRING */,
  sourceFile: "werd_2014.gif" /* STRING */,
  sourcePath: "Meghan" /* STRING */,
  timeout: undefined /* INTEGER */
// result: INFOTABLE dataShape: FileTransferJob
var result = Subsystems["FileTransferSubsystem"].Copy(params);
  • The following is the entire Java file (provided in the Java SDK download) that sets up Virtual Directories for a file transfer.
    • If you look at the custom service above to see that we are referencing the targetPath for a directory that is defined in the Java class.
package com.thingworx.javatransfer;
import com.thingworx.communications.client.ClientConfigurator;
import com.thingworx.communications.client.ConnectedThingClient;
import com.thingworx.communications.client.things.filetransfer.FileTransferVirtualThing;
public class FileTransferExample {
  // Substitute your thing name here
  private static final String ThingName = "FileTransferExample";
  public static void main(String[] args) {
  // Create a client config
  ClientConfigurator config = new ClientConfigurator();
  // Basic configuration. See SimpleClient.java for additional info.
  config.setUri("wss://localhost:8443/Thingworx/WS");
  config.setAppKey("8737c3b9-bc65-4ac8-8990-64b565487cd3");
  config.ignoreSSLErrors(true);
  try {
  ConnectedThingClient client = new ConnectedThingClient(config);
  FileTransferVirtualThing myThing = new FileTransferVirtualThing(ThingName, "File Transfer Example", client);
  // Add two virtual directories that will act as the root directories in this
  // application's virtual file system.
  myThing.addVirtualDirectory("in",  "/home/meg/files/in");
  myThing.addVirtualDirectory("out", "/home/meg/files/out");
  client.bindThing(myThing);
  client.start();
  while(!client.isShutdown()) {
  Thread.sleep(5000);
  } catch(Exception e) {
  e.printStackTrace();
Let me know if you have any further questions.
Meghan
Sujith,
var params = {
  try {
  client.start();
  Thread.sleep(5000);
Meghan
ses1-VisitorAuthor
Jul 28, 2016 5:15 AM UTC
A million Thanks, Meghan.
The description from your perfectly answers my question.
Yea, the code I had tried was similar to what you have provided.
But the problem was there at how I configured params.
Now it is perfectly fine, Thanks again !!!
Oct 13, 2016 2:54 PM UTC
Sujith, is there any chance that you could share me your knowledge about sending files to Thingworx? I'm stucked trying to send a picture from a smartphone to a Thingworx platform and I have no idea on how to implement FileTransfer with the Android SDK.
I'll apreciate your help.
