Transfer infotable data between two contained mashups
- 2 replies
- 2197 views
- Translate All
Hi all,
I have two contained mashups, A and B. Both have an infotable with the same name and with the same data shape as their mashup parameter. Both are contained (side by side) in mashup C.
In mashup A I put some data directly into the info table (the mashpu parameter info table) and I would like to get that information on mashup B and present it.
I can't seem to see the information on mashup B.
For some reason - it seems that the information doesn't even leave mashup A since I'm trying to see the infotable in a grid on mashup C and the grid shows nothing.
I've attached the following files:
Mashups_testDataTransferOut.xml is mashup A
Mashups_testDataTransferIn.xml is mashup B
Mashups_testDataTransfer.xml is mashup C
What am I missing?
(Note: I do know that in order to transfer one string I don't need info table, but this is only an example...
In reality - I need to transfer a lot of data between the mashups and I would like to be able to do that with one bind (the infotable))
Amiad.
