Aug 20, 2018 10:08 AM UTC
Tree advanced grid - column link to open mashup in popup
I want to open a mashup in a popup when we click on the link column in a tree advanced grid.
How to enable a column as link in tree adv grid?
how to open a mash up as popup from tree adv grid?
Pl assist.
Aug 24, 2018 1:00 PM UTC
Hi @pselvaraj-1 that widget provides DoubleClick event that you can use to invoke to pass the selected row name,which you can combine with Navigate widget which has option to show popup like so 24-08-2018 14-53-46.jpg
and then bind the mashup name and select popup for the targetWindow
So now double click on the row should get you something like this
Hope this helps.
Hope this helps.
Aug 28, 2018 9:17 AM UTC
Thanks for your time and solution. We already showing a pop up on double clicking the row.
But the requirement is instead of double click on the row, create a hyperlink in any one of the column value or separate column with the hyperlink "View" to open modal popup when the user clicks. PL help!
