11-Garnet
TreeGridAdvanced expand/collapse All
Hi Everyone,
I am Thingworx developer , I want to Expand All / Collapse All Results in TreeGridAdvanced,
I try to use property "ExpandLoadedRows" which is bindable - so I bound a Checkbox to this value, but it didn't work for me. It worked only when I set this property checked by default which shows me only expanded rows.
Please Help me how can I achieve !
Hello @NJ_10144761 ,
I assume you have to create your own custom widget to achieve expand all/collapse all. Pls share the version of your ThingWorx for my better understanding. also you can refer this community post hving solution of the similar issue:
https://community.ptc.com/t5/ThingWorx-Developers/In-tree-widget-if-i-want-2nd-level-data-as-default-selected-how/td-p/516312
Hope it helps!
Bhawna
Hope it helps!
Bhawna
11-Garnet
Hello @bchaudhary_448008 thanks for reply, currently I am using thingworx ThingWorx 9.2.3.
