8-Gravel
Trigger a Scheduler on ThingWorx Restart
Is there any event that triggers on ThingWorx restart?
We need to call the subscription to update the current device status in the datatable after ThingWorx restart.
Hi @PG_CG ,
ThingStart event is the event that triggers with every thing. Also you can follow the belo given article to create custom event in ThingWorx:
https://www.ptc.com/en/support/article/cs224727
Kindly check an let me know if you find this useful.
Regards
Bhawna
Hi @PG_CG ,
Regards
Bhawna
