Trigger Thingworx workflow from Vuforia
we are conceiving a "near real-time" AR experience in which all the entities are retrieved from windchill "live" resources, whatever the lifecycle state they are. These are the expected requirements:
  1. the AR experience is designed with a preset template (onclick events, relevant documents exposition, buttons, etc.)
  2. The entire javascript source code should be parametrized pointing at the known part/order number
  3. thingworx workflow should get data from windchill (pvz files and all relevant data or documents)) every time the experience is launched (vuforia view points at a thingmark or another target)
Do you think it is feasible? What tools/procedures can be useful?
Many thanks
GianVal15-MoonstoneAuthor
I just noticed that it is possible to trigger a workflow from a simple webhook. Probably I can embed the webhook URL of the trigger just before lunching the experience from Vuforia View (or with a specific "sort of" update button). Awaiting some confirmation from someone who has faced a similar use case. Thank you
