Trying to add a service result to another service
i'm trying to give the result of 1 service that is infotable  to another service
Please help me out
Hi @Irfan_Pasha ,
Use Me/Entities option to find your service, use the snippet.
Regards
Janakiraman
Thank you,
I tried that one too ,
but i'm unable to get the desired output.
how to store that in a new variable.
store it in a normal JavaScript variable.
var serviceResult=<service call>;
if not getting, post your code here.
Janakiraman
Support
Hi @Irfan_Pasha.
Since it sounds that you now have a solution, please mark the appropriate response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
