Trying to create Expand collapse the container using button
Hi Team,
as i shown in below image , trying to create Expand and collapse button on container,
but in second container(Chart) button i need at top right above the chart. Is it possible in Thingworx 9.3?
pls suggest how we can design this.
VS
Make container as fixed size in layout tab and try following article...
Expanding and Collapsing Containers
Hello Sathish,
Thanks for the reply, I followed same article but still  can't achieve as i want . pls see below use case
I have metric and Graph panel , if I expand metric, two more metrics should see (Total 3 are there , by default only 1 can see without expand). It means can we adjust Collapse size upto two metric?
VS
try import and test... hope it will be helpful.
