pshashipreetham
Jun 3, 2025 11:01 AM UTC
Turn off Trace Logs
I have an instance where the trace logs are generating heavily, resulting in data exceeding 50GB in just a couple of hours in PROD, and the C Drive becomes out of memory, causing the entire server to crash.
I need to disable only the trace logs in ThingWorx. I tried to find an article, but none have been found as of now.
How can we disable the Trace Logs in Thingowrx?
Thingworx Version: 9.0
Rocko
RockoAnswer
Jun 3, 2025 12:12 PM UTC
How did you set it to TRACE?
You can try Monitoring>Application Log>Configure>LogLevel->Warn.
FYI Newer versions of ThingWorx auto-reset from Trace level after a defined period to avoid the situation you describe.
Rocko
Rocko19-TanzaniteAnswer
