8-Gravel
Two-Factor Authentication for Thingworx Platform
Has anyone implemented Two-Factor authentication in Thingworx, either by using custom code or a third party ?
I have to create a solution that has 2 factor Authentication, but I have never done it so any help would be appreciated
This is already discussed in one of the post which stands same till today .
https://community.ptc.com/t5/ThingWorx-Developers/Two-factor-authentication-for-Utilities/td-p/505214
Thanks ,
Mukul Narang
Hi @apretorius
I just wanted to follow up with you to see if any responses to your question on the PTC Community answered the questions you had. If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
Vibhuti
8-Gravel
Hey there
No. I have tried using the sample provided in the thingworx training, but that does not work at all.
Which sample you are trying ? Can you please share the link of the training so that I can relate to it .
Thanks ,
Mukul Narang
